where to start ?
puffeltje
where to start ?
Post by puffeltje »
I downloaded and installed 'installaware free'. I am using VS2010. But i don't see installaware at the project templates. Am i looking at the wrong place?
giaviv
Re: where to start ?
Post by giaviv »
Where exactly are you looking?
puffeltje
Post by puffeltje »
the documentation says:
On the Project tab, in the New group, click any button.
Click the InstallAware button, then choose New ProjectOther
In VS2010 (VB) i see no project tab. When i use the menu: "File - New - Project..." i only see the standard installed templates but nothing that looks like installaware.
giaviv
Post by giaviv »
Hey,
That documentation is referring to the InstallAware IDE, not the Visual Studio plugin.
You have to be able to run the IDE directly to access these functions.
puffeltje
Post by puffeltje »
From where can i run the IDE directly? In the installation folder i see a executable "miaa.exe" but when i execute this file i get the error: "Installaware Free Edition cannot be launched uotside of Visual Studio."
When i look inside visual studio i don't see any menu or button where i can start the installaware IDE.
giaviv
Post by giaviv »
Exactly - as I said, you have to be able to run the IDE, which you don't because you are running the free version.
puffeltje
Post by puffeltje »
Is there documentation available specially for the free-version?
giaviv
Post by giaviv »
The Visual Studio add-in which constitutes the Free Edition is pretty self explanatory.
If you have any specific questions, please go ahead!
puffeltje
Post by puffeltje »
I still don't know if installaware is installed correctly.
Is the free version an add-in? in the add-in manager i don't have any add-in available.
How can i see that installaware Free is installed correcly?
giaviv
Post by giaviv »
InstallAware Free is the InstallAware Engine coupled with the Visual Studio add-in.
Though you cannot run the IA IDE directly, you can build setups within Visual Studio.
Are you able to see the InstallAware ribbon inside Visual Studio?
puffeltje
Post by puffeltje »
I have no ribbon (as in MS Office) in VS2010. If you mean the toolbars: i don't see an installaware toolbar in VS2010.
giaviv
Post by giaviv »
Do you not see this in VS?
puffeltje
Post by puffeltje »
I don't have a menu-option 'installaware' and i don't have a toolbar 'installaware"
Is it a problem if i installed VS and installaware not on drive C? at the moment i installed VS and installaware on drive E.
giaviv
Post by giaviv »
That should not be a problem - please try reinstalling InstallAware.
puffeltje
Post by puffeltje »
i re-installed it a dozen times, with no luck. I tried different ways:
uninstalling with an uninstaller so that the registry is cleaned
reinstalled as an administrator
Next week i try to install it on my other computer when i 'm back home. For this vacation i'm through with it. If it doesn't install on my other computer i'll go searching for alternative software. Lets hope i can give a positive result next week.
thanks so far for the support.
