The default $TARGETDIR$ is "hard coded" inside the IA script.
But you can change this using the CMDLINE.
example:
msiexec /i Setup.msi CMDLINE="PATH=C:\\NewDir\\Subdir"one problem though:
I need to check if the last character of the string is "\" , if not, add "\" to the variable.
I've tried to use the "Extract File Folder" function, but if the last character of the string is not "\" It will not be recognised as a subdirectory.
For example:
PATH = "C:\\Dir_1\\Dir_2 will result in "C:\\Dir_1\"
How can I check if the last character is a forwardslash(/) of backslash(\\)?
