Run .Net Installer on 64 bit OS
PietJan
Post by PietJan »
I am trying to run the Run .Net installer command for installing a MMC snapin.
The installation should be done in 64-bit mode. However it seems that the Run .Net Installer class calls the installutil in the 32bit framework dir instead of the 64bit dir.
How can I force the Run .Net Installer to use the 64-bit framework installutil ?
regads
PietJan
PietJan
Re: Run .Net Installer on 64 bit OS
Post by PietJan »
In addition the following command on the command-prompt works fine and installs the MMC snapin correctly
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\InstallUtil.exe" -i XYServer.MMC.dll
However I thought the Run .Net Installer would select the correct framework (32-bit or 64-bit) automatically if the 64bit flag of the setup was set.
But it seems that the Run .Net Installer uses the 32-bit version of the InstallUtil.
Do I need to change something in the setup project to force the Run .Net Installer to use the 64 bit installutil ?
regards
PietJan
