When I run my setup, I get error 2324 as shown in the attachment.
The error occurs when I call the "Apply Install".
If I remove some MSI code that calls InstallFiles, the error does not occur. The files referenced by Install Files do exist on disk.
Can you advise?
Error 2324
Error 2324
- IA2324.png (38.04 KiB) Viewed 4722 times
Re: Error 2324
Where are you installing the files from? Does the installer have permissions to that location?
How did you create your setup (which template did you use)?
What customizations have you made to the setup?
Re: Error 2324
I resolved the error. Some files were indeed missing.
