Big differences in Wizard Loop..why??
ErikB
Postby ErikB » Mon Mar 20, 2006 8:46 am
I am seeing big differences in the Wizard Loop of two installations, and for the life of me I cannot find out why. The two installations were built in the same InstallAware version (5.2), with the same wizard options. The one Loop looks like:
wizard loop
Display Dialog: welcome
[compiler if Variable BUILDMODE not Equals PATCH]
// Display Dialog: licensecheck
// Display Dialog: readme
// Display Dialog: registration
Display Dialog: destination
Display Dialog: startmenu
Display Dialog: dbconfig
Display Dialog: sfconfig
Display Dialog: smtpconfig
[compiler end]
Display Dialog: startinstallation
GoTo Label: Main Install
While the other looks like:
label: Welcome Dialog
if Variable WIZARD Equals CANCEL
label: License Check
if Variable WIZARD Equals BACK
GoTo Label: Welcome Dialog
else
label: ReadMe Information
GoTo Label: License Check
else
label: User Registration
GoTo Label: ReadMe Information
else
label: Setup Type
// Display Dialog: setuptype
GoTo Label: User Registration
else
// TO-DO: Customize your minimum setup here
if Variable MINIMUM Equals TRUE
Select Component: Colibri Premium Backend
else
if Variable COMPLETE Equals TRUE
label: Custom Setup
Display Dialog: componentstree (if variable PERSONALIZED is TRUE)
GoTo Label: Setup Type
else
label: Destination Directory
GoTo Label: Custom Setup
else
label: Start Menu
GoTo Label: Destination Directory
else
label: SMTP Server Setup
GoTo Label: Start Menu
else
label: SQL Server Setup
GoTo Label: SMTP Server Setup
else
label: BES Server Setup
Display Dialog: besconfig
GoTo Label: SQL Server Setup
else
label: Connector Config
Display Dialog: colibriconfig
GoTo Label: BES Server Setup
else
[compiler end]
label: Start Installation
GoTo Label: Connector Config
[compiler else]
[compiler end]
else
I apologise for the long post, but this is puzzling me. The latter has my absolute preference as I believe it allows for far more fine-grained control.
It's probably something incredibly simple..
Thanks in advance,
Erik
PS. The two applications to be installed are different, hence the minor differences in the dialogs used..
Postby MichaelNesmith » Mon Mar 20, 2006 3:23 pm
Hi Erik!
The Project Wizard creates the simpler loop if you say you will be disallowing custom setups in the Dialogs page.
Otherwise, most (if not all) the standard templates, along with the other options available in the Project Wizard, create the longer version.
You can just copy-paste code if you want to switch "styles" - nothing is hard-coded in your projects, so everything that is offered by the wizards/templates are just "baseline" suggestions.
Users browsing this forum: No registered users and 105 guests
