Install a file system driveService with startup type at Boot
Debstep
Postby Debstep » Tue Mar 28, 2006 2:51 pm
Is there a way to install a file system driver service that starts at boot time?
Thanks in advance.......
Postby MichaelNesmith » Tue Mar 28, 2006 4:13 pm
Hi Deb,
I think this sounds like a non-standard service, more like a file system driver? In that case, I believe you will need to directly create the necessary registry entries required by the service.
As for your other question (in your email), doubleword is the same thing as Integer, so just write an Integer value in the Write Registry command.
Debstep
Postby Debstep » Tue Mar 28, 2006 4:35 pm
Thanks so much....Too bad about the file system driver. ...
Users browsing this forum: Bing [Bot] and 105 guests
