I'm coming off of InstallAnywhere where you can issue a "RefreshEnviornment" Action after setting Env. variables.
InstallAware doesn't seem to fully refresh the system environment after setting variables.
Can this be fixed?
Chris
Set Enviornment doesn't refresh Enviornment
Re: Set Enviornment doesn't refresh Enviornment
I'm using IA12.
Chris,
Can you please further elaborate about this - what exactly are you trying to do, and how are you observing the wrong behavior?
Essentially, the installer sets a bunch of Environment variables and correctly sets the HKLM\SYSTEM\CURRENTCONTROLSET\SESSION MANAGER\ENVIRONMENT keys; however, when opening a command prompt or running an application after the fact, the environment isn't refreshed/ updated.
Shouldn't InstallAware call:
SendMessageTimeout(HWND_BROADCAST, WM_SETTINGCHANGE, 0,
(LPARAM) "Environment", SMTO_ABORTIFHUNG,
5000, &dwReturnValue);
To correctly refresh the System Environment?
Chris
Chris
Chris,
You can use the Call DLL Function MSIcode command to achieve this - just pass along the parameters you specific above and that should work!
I figured it was doable, but was just wondering why there isn't any built in functionality
. If a developer "Sets Env. Var" I'm sure 99.9% of the time they'd want the system env. refreshed.
Also, What DLL would you target here, my assumption is user32.dll
Yes its indeed user32.dll.
Actually, when you set environment variable in cmd, they dont refresh automatically either..
Is there any chance InstallAware will have this call built in in an updated version? Your competition (InstallShield/ InstallAnywhere) both provide "Refresh Environment" calls.
I'm still having problems calling this in user32.dll.
The following post was never answered by another user with a similar issue:
http://www.installaware.com/forum/viewtopic.php?f=2&t=2754
Just curious
Chris
Just curious
Chris
Chris,
Thank you for your input. We will do out best to support this in the future.
What problem are you having with calling user32.dll?
The problem is passing in arguments to the SendMessageTimeout(HWND_BROADCAST, WM_SETTINGCHANGE, 0,(LPARAM) "Environment", SMTO_ABORTIFHUNG, 5000, &dwReturnValue); using the Call DLL function and User32.dll.
Do you know how these would be passed in?
Not matter what I try, it's not working. I've posted a link to someone with similar problems back in 2007...
Chris
Chris
Hey Chris,
This should. As a workaround, you can create your own dll than calls this function from user32.dll, and invoke this dll using the Call DLL Function command.
Users browsing this forum: No registered users and 89 guests
