Remove Unpinned Assemblies in Win7 x64
Bjarne
Post by Bjarne »
Hi all!
I got a strange problem, the "Remove unpinned assemblies" encounter some kind of error ( see attached screenshot, French unfortunately).
The actual assembly gets removed from C:\Windows\Assembly so I don't really know whats actually failing?
I've only able to reproduce the problem in Win7 x64 environments but it is 100% reproducible.
The installer only installs one assembly in the GAC and this is also the only reference to this assembly. The package is running in x64 mode.
Enviroment: Installaware:
IA12, build Moooya.8.4.11,
Win2K8 R2 English
Enviroment: Test machine:
Win7 Enterprise x64
Error from a french Win7...
giaviv
Re: Remove Unpinned Assemblies in Win7 x64
Post by giaviv »
Could you please send your project and the assembly in question to support at installaware.com? Thanks!
Bjarne
Post by Bjarne »
The project is sent as requested
giaviv
Post by giaviv »
I have tested out your project on Win7 x64, and did not have this problem. Could you please send me the installer binary that you build?
