bad transparency with rzbmpbutton
rosstrusler
Post by rosstrusler »
I'm using RzBmpButtons, with various bitmaps assigned.
Button.Bitmaps.TransparentColor is set to clWhite. Button.Color is set to Blue, although it shouldn't matter. White is around the edges of the images, which when masked, gives them a rounded look.
The problem is that the transparency is not transparent. Instead, the white is replaced with black. Ideally it wouldn't be painted at all. If it was replaced with Blue, at least it would work on my solid background. See image below.
giaviv
Re: bad transparency with rzbmpbutton
Post by giaviv »
I am afraid that this is a Windows Forms behavior and there is little that we can do about that. I apologize for the inconvenience.
