Dear specialists,
4 weeks ago I bought the new version IA12. The directorys \net40bin*\ were not created and filled.
I used the full installation, and in "Add or Remove Features setup option" the options for .net 4 are all "fully installed on hard disk".
I searched in the forum for it and I downloaded a lot of files, but no one match.
Perhaps you may send me a link to download de used directories in a z7-File.
Thanks for answers.
Yours,
Jürgen Fischer
No files match pattern: net40clientbin_x86\*.*
JuergenFischer
Re: No files match pattern: net40clientbin_x86\*.*
Jürgen,
Did you use a web install of InstallAware or a single binary?
JuergenFischer
Dear Aviv,
I use'd the single file to install IA 12.
But I could resolve the problem now.
I've found "runtime updates für VS 2010", installed it and the directorys are at the right position.
The problem for you Installaware is, that with the free installation for test these directorys not aviable.
Perhaps IA must modify the Single File Setup.
Greatings and thanks
Jürgen
Jürgen
