I know the way under installshield to create a webinstaller that creates some html and checks if version x is installed, if not install, if yes just skip.
The benefit is that the html can run every time on startup of an web application for the install without prompting for exceute an file.
I'm very certain installaware can do this as well, but can not figure it out.
Can some one pls point me into the right direction?
thanks
Web Install
Re: Web Install
Are you referring to Microsoft's OneClick?
By html do you mean that you can install an application by visiting a certain webpage?
Re: Web Install
See the code below
See the code below
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<html>
<head>
<!-- installing.htm - sample page for -->
<!-- One-Click Install installation page -->
<!-- Copyright © 2001-2002 InstallShield Software Corporation -->
<title>InstallShield One-Click™ Install - QBT Setup</title>
<meta http-equiv="Content-Type" content="text/html; charset=windows-1252;"/>
<meta name="vs_targetSchema" content="http://schemas.microsoft.com/intellisense/nav4-0">
<style media="all" type="text/css">
BODY {
font-family: "Verdana", "Arial", sans-serif;
font-size: xx-small;
color: black;
background-color: white;
margin: 0em;
IMG {
border: none;
P {
A {
color: #002B55;
HR {
width: 100%;
height: 1px;
color: #002B55;
TD {
text-align: left;
vertical-align: top;
.upperleft {
background-image: url(UL.gif);
background-position: top left;
background-repeat: no-repeat;
.upperright {
background-image: url(UR.gif);
background-position: top right;
.lowerleft {
background-image: url(LL.gif);
background-position: bottom left;
.lowerright {
background-image: url(LR.gif);
background-position: bottom right;
</style>
<script language="JavaScript">
// Determine the browser version.
ns = -1;
ie = -1;
var reqstring;
if (navigator.appName.indexOf("Microsoft Internet Explorer") != -1)
if (parseFloat(navigator.appVersion) >= 4.0)
ie = 1;
else if (navigator.appVersion.indexOf("MSIE 3.02") != -1)
ie = 1;
else
reqString = "Microsoft Internet Explorer 3.02 or higher";
else if (navigator.appName.indexOf("Netscape") != -1)
if (parseFloat(navigator.appVersion) >= 4.04)
ns = 1;
else
reqString = "Netscape Communicator 4.04 or higher";
else
reqString = "Netscape Communicator 4.04 or Internet Explorer 3.02 or higher";
function WriteInstallingMsg()
if ((ns == 1) || (ie == 1))
document.write("Installing QBT...");
function WriteBrowserTooOldMsg()
if ((ns == -1) && (ie == -1))
document.write("Cannot install QBT. " + reqString + " is required.");
</script>
</head>
<body onLoad="window.close()">
<map name="Help">
<area href="http://support.installshield.com/help/oneclick/defaulthelp.htm" target="_blank" coords="470, 65, 535, 90" shape="rect">
</map>
<table border="0" cellpadding="0" cellspacing="0" style="width: 100%; height: 120px; background-image: url(header_fill.jpg); background-repeat: repeat-x;" id="Table1">
<tr>
<td style="width: 639px;"><img src="oci_header.jpg" width="639" height="120" border="0" usemap="#Help"></td>
<td> </td>
</tr>
</table>
WriteBrowserTooOldMsg(); // On Netscape 3.03, document.write doesn't work inside tables.
</script>
<center>
<table border="0" cellpadding="10" cellspacing="0" style="width: 60%; background-color: #EDF1F4; margin-top: 1em;" id="Table2">
<tr>
<td class="upperleft">
<span style="color: #002B55; font-size: medium;"><script language="JavaScript">WriteInstallingMsg();</script></span>
<noscript>
<b>Please enable both Javascript and Java in your browser through the Options or Preferences menu in your browser and reload this page.</b> If your browser does not support Java or Javascript, please install one of these browsers and return to this page.
<ul>
<li><a href="http://www.microsoft.com/windows/ie/">Microsoft Internet Explorer</a></li>
<li><a href="http://browsers.netscape.com/browsers/">Netscape</a></li>
</ul>
</noscript>
</td>
<td class="upperright"> </td>
</tr>
<tr>
<td colspan="2"><hr noshade></td>
</tr>
<tr>
<td>
<p style="color: #002B55;">
<b><span id="txtSize">580 K</span></b>
<br>
<b><span id="txtModemTime">1 minutes 48 seconds</span></b> over a dial-up connection
<br>
<b><span id="txtBroadbandTime">12 seconds</span></b> over a broadband connection
</p>
</td>
<td> </td>
</tr>
<tr>
<td class="lowerleft"> </td>
<td class="lowerright"> </td>
</tr>
</table>
</center>
if (ie == 1)
document.write("<object CLASSID='clsid:1D5C0A70-D5DF-41E7-B6E3-CE6DA94E1621' CODEBASE='install.cab#Version=4,0,0,4' BORDER=0 VSPACE=0 HSPACE=0 ALIGN=TOP HEIGHT=0% WIDTH=0%></object>");
else if (ns == 1)
document.writeln("<applet archive=\"install.jar\" code=\"ISSetupApplet.class\" height=\"0\" width=\"0\"></applet>");
</script>
</body>
</html>
Re: Web Install
Sascha,
We apologize, but InstallAware does not support OneClick.
