Hi!
I am currently writing the Installer for our program 'B' that is a kind of add-on to our program 'A'.
So I want to check if program 'A' is installed before installing 'B'.
How can I check this?
Program 'A' is not creating registry entries, but I know its Product-Code.
The installer for 'A' can hardly be enhanced to writing registry entries as it is already shipped to our customers.
I also would need to find out the $TARGETDIR$ of 'A' because 'B' has to be installed in the same dir without asking the user again.
Can this be accomplished?
How to check if another application is installed
MikeFieger
First is easy - use the Is MSI Setup Installed command. This works with the GUID that you already know, so its great way to do it.
Second - this will be trickier. You have to know some registry key, some product file, some way to track down a change made by the product. You can try Find All Files, Read Registry, etc. from that point onwards...
...but there's got to be a starting point!
