I am trying to share a common folder and set the access to it. Here is what I did:
1. In Files, I made two sub folders under $COMMONFILES$.
2. I then shared the $COMMONFILES$ folder, in Server Configuration.
3. Then I went into Advanced Options|Access Control and clicked NEW, selected Share (folder share), Authenticated Users, Set Chosen Users with Access Rights, checked Read and Write, then tried to select $COMMONFILES$ with the Browse button. I can click on the $COMMONFILES$ Target Folder in the left pane, but it will not show up in the right pane and the OK button is disabled.
How do I set access control for a folder????????
Access Control BUG!!?
Re: Access Control BUG!!?
Sounds like you did set the permissions - please try running the installer and seeing if it worked.
