how to Display a simle message box containing a custom messa
Debstep
Post by Debstep »
I would like to display a simple dialog box with an ok or ok cancel button that will show a message to a user . I have this message stored in a variable and I wish to use this message box to display whatever message I put into the variable.
I created a dialog and tried edit text , memo, static text etc but whatever I do I can only get it o display $ERRORSTRING$ not the actual string.
Anyone figured out how to do this?
Thanks for any hints
jimo
Post by jimo »
Try using a label with your variable in the caption property.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
Debstep
Post by Debstep »
Thanks that worked...I just wanted something a little more customizable then the regular message box....
