Edit Web.config IA 2012
StyX
Post by StyX »
I'm trying to edit a Web.config file using the Edit XML File command, but I can't seem to get it to work.
The value I'm trying to change looks like this:
<add value="http://7.4.2.193/Mobile/"/>
I want to change the url during the install.
The value is located under <configuration> <microsoft.identityModel> <service> <audienceUris>
I've got the Element Path set to:
configuration\microsoft.identityModel\service\audienceUris\add
and attributes set to: Name = value and Value = http://ir2/InFrontMobile/
Is it possible to use the Edit XML File command for this or am I stuck with EditFile ?
giaviv
Re: Edit Web.config IA 2012
Post by giaviv »
What you can do to work around this is to remove that value (the entire <add value....> key) and recreate it with the new value.
