I've recently purchased IA2012 Studio version. I'm trying to create an installation package for a Visual Studio 2010 c# program that I've written. I don't see where InstallAware has integrated into Visual Studio. I have installed / reinstalled. removed / reinstalled IA using my admin account as well as running the install using Run as Administrator. Same results.
Any Help would be appreciated.
InstallAware 2012 and VB Integration
Re: InstallAware 2012 and VB Integration
I'm wondering if you need to do a custom installation and enable the VS integration? I'm sure it's enabled by default but it might be worth checking. There is a feature in the custom setup option that will confirm it for you.
