How to update Web Site install?
halox
Post by halox »
I'm evaluated version 12 at the moment, and have a query as to how to update an existing installation of a web site. During a new install I have the following occurring:
New Install
  • Install pre-compiled ASP.NET files to a location
  • Apply NTFS permissions to files for certain IIS accounts
  • Create IIS Web Site
  • Write Registry Entry
  • Install & start Windows Service
I would like to be able to perform an update with the installer as well with the following desired results:
Desired Update Install
  • Stop Windows Service
  • Do not touch the Created Web Site in IIS or the Registry Entry
  • Update pre-compiled ASP.NET files in the same location, but ignore updating certain files i.e. web.config file
  • Start Windows Service
Does anyone know if this is possible at all?
Thanks in advance.
giaviv
Re: How to update Web Site install?
Post by giaviv »
When you include web updates, a designated script (called updates) is added to your project.
What you can do is add the functionality you were trying to get when updates occur to your updates script.
