Problem creating Virtual Folder
grojas1980
Post by grojas1980 »
I have the Create Virtual Folder command telling it to set the ASP.NET version to 4, but when it creates the virtual folder it creates it at 2.0
.NET 4 is installed on the target server.
giaviv
Re: Problem creating Virtual Folder
Post by giaviv »
Can you please attach here the script you are testing with?
grojas1980
~InstallAware Clipboard Data~
~Create Virtual Folder~
~{80429F19-6A02-4572-BEB3-61C0127369B7}~
~CJACMECFWebServices~
~$WWWROOTDIR$\CJA\CJACMECFWebServices~
~FALSE~
~TRUE~
~FALSE~
~FALSE~
~TRUE~
~TRUE~
~2|CJA~
~1|3~
~FALSE~
~Default.htm,Default.asp,index.htm,Default.aspx~
~TRUE~
~TRUE~
~FALSE~
~$WEBSITEINDEXVAR$~
