I have recently release a new version of an app. I have published 4 patches successfully. I have create a 5 patch that runs fine. However; now, when I run the auto updater it finds the 5th update to be installed but when I click install, I get the following runtime error:
Runtime error in setup script
Source File: updates
Line number: 369
" is not a valid integer value.
Does anyone have an idea of what's going on?
Source file: updates
Re: Source file: updates
You can actually run your installer in debug and force it to go to the updates script (by for example explicitly including the updates script).
Then, run your update script line-by-line and see what the problem is.
