Installation process When cancel
Post complete new themes or wizard dialogs here.
ddcuat1
Post by ddcuat1 »
When we cancel the installation process,the warning window should show like this.
1) Header text is “Company Name” with Company Logo icon.
2) Alert image(i.e warning image).
But when we cancel the installation process it is showing header text what we changed but i need to show my company logo and alert message also is it possible to put company logo and alert message.
if yes, how i can do please help me i am using installware 12 version.
Sandeep
giaviv
Re: Installation process When cancel
Post by giaviv »
Sandeep,
What do you mean by "when we cancel the installation process"?
ddcuat1
Post by ddcuat1 »
Hi giaviv,
please see the attachment, in this window i want to place my company logo and warning images. how can i do that. please help me.
issues while installing.doc
Cancel Window
(68.5 KiB) Downloaded 17960 times
giaviv
Post by giaviv »
I see that you already changed the title as well the icon. Unfortunately, you cannot customize this any further.
ddcuat1
Post by ddcuat1 »
Hi Aviv Giladi,
here my problem is, when i click on cancel button it is showing cancel dialog window, in that i am able to change text in screen1, but i need to put logo's in Title bar and in content text place in screen2 is it possible r not. if s how can i place. look in attachment, please help me.
Cancel Installation Window.doc
Cancel Window
(29 KiB) Downloaded 13162 times
giaviv
Post by giaviv »
I apologize, but that is not possible.
ddcuat1
Post by ddcuat1 »
ok, thanks for ur help.
CecilBaker
Post by CecilBaker »
ddcuat1 wrote:Hi,
Sandeep
Yes, it is possible to customize the warning window that appears when the installation process is cancelled in InstallShield 12. You can follow the below steps to add your company logo and alert message to the warning window:
Open the InstallShield project and select the "Dialogs" view from the left-hand pane.
Find the "CancelDlg" dialog in the list and select it.
In the right-hand pane, you will see the properties of the selected dialog. Scroll down to the "BannerBitmap" property and select the ellipsis button.
In the "Banner Bitmap" dialog that appears, you can browse to and select your company logo image file.
Next, you will want to add your alert message. Scroll down to the "BodyText" property and enter your desired message.
