I have a IA setup with a Web Media Block to download DotNet Framework 4 from an URL.
Problem is:
in my company we have a proxy server and all users need to login with a user name and a password.
In the Internet Explorer settings we use an Automatic Proxy configuration URL like;
http://myweb/test/proxy.pac
I can not download the Web Media Block files if there is a proxy server which needs Login with user name and password.
It also does not work if I first open Internet Explorer, log into the proxy with my username and password and then try to install.
Is there any solution for that?
regards
Hans
Web Media Block Proxy Settings?
Re: Web Media Block Proxy Settings?
No idea or solution for that?
Hi Hans,
We have tried reproducing this with a local proxy server and had no such problems. Are you certain that your proxy is properly configured?
yes I am sure that my proxy is correct.
If I use the URL and ../proxy.pac and open the IE I will be prompted for Proxy Login with User name and password.
Also if I fill in the Proxy TCP/IP address in the Internet Explorer settings I will be prompted for user name and password.
But I will never prompted when trying to download a Web Media Block
rergards
Hans
rergards
Hans
mikKummerfeld
Same problem here. In SharedStrings there are Strings like Proxyname and Password, but I never get this dialog...
I use pac file on proxy server as well...
please help
please help
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Heiko Kummerfeld
MIK GmbH
