Scripting Suggestion
Orionizer
Postby Orionizer » Tue Apr 04, 2006 8:48 pm
Would (or is) it be possible to enable free-form scripting? Sometimes the step by step method slows me down considerably...
Postby MichaelNesmith » Tue Apr 04, 2006 11:45 pm
Are you trying to type in directly in the script editor? This is available since 5.0 and it speeds up the process a lot.
Orionizer
Postby Orionizer » Wed Apr 05, 2006 8:27 am
I see that now - I guess I never tried it.
What I HAD tried in the past was pressing [ENTER] to create a blank line, but that modifies the current line. What I think would be a good idea is to add an item to the context menu that says "Insert blank line here" or something like that...
Debstep
insert blank line
Postby Debstep » Wed Apr 05, 2006 10:28 am
You can enter a blank line by typing COM then enter twice.. It basically starts the comment line and inserts a blank comment. ...at least this is my method :)
Orionizer
Postby Orionizer » Wed Apr 05, 2006 12:12 pm
Thanks Debstep! Good Tip!
Users browsing this forum: No registered users and 65 guests
