How to change updates URL after installation?
MatDeveloper100
Post by MatDeveloper100 »
Hello
In the IA there is a property Monitor URL for web updates.
Is there any way to change it after installation?
E.g. use case:
User installed the application, and then support moved all patches to the another server. So now we need to provide new full installation to the user instead of changing just URL.
giaviv
Re: How to change updates URL after installation?
Post by giaviv »
If you look at the updates script that is added to your project when you enable updates, you will see where the MSIcode checks the updates.ini file on the server.
You can modify this command however you want, and for example, store the address in the registry.
