Uninstaller is leaving behind all empty folders
In 2012, when I run the uninstaller, all files installed are removed; however, every folder that contained files is left behind, it doesn't remove a single folder.
Re: Uninstaller is leaving behind all empty folders
Does a reboot solve this?
No, it doesn't.
Chris
Chris
Chris,
Which engine are you using (native/windows installer)?
