I have two projects that will NOT open due to the ‘EditFile’ plug-in used in IA9.
I followed the error message window instrutions, but cannot find the EditFile plugin in the IA original build because it was added later.
I have searched all the files in the project directory trying to find the problem.
Help!
Append:
Okay, I have installed the correct plugin and project loads fine, BUT the project will NOT compile due to EditFile plugin error.
Here's what I want:
- Remove all EditFile plugin info from the project files. I don't need it anymore!
Q. What project files contain the EditFile info that prevents my project from loading?
I like IA 2012 very much, but cannot use it until this issue is resolved.
Help!
IA 2012 Fail On Open Project IA9 EditFile Plugin?
- EditFile_Fail_OnStartup.png (29.58 KiB) Viewed 3628 times
Re: IA 2012 Fail On Open Project IA9 EditFile Plugin?
Please follow up with this on this same thread in the plugin forum. No need to submit the same thread more than once.
