Legacy InstallAware Installers can be found here!
ckaware
Postby ckaware » Thu Dec 15, 2011 8:53 am
Hello all,
Rant: InstallAware should PROVIDE customers with an easy way to generate LICENSES for LEGACY PURCHASED SOFTWARE!. If I pay for 10, download 11, I should still be able to generate my license for 10...
Please find legacy (and current) installers here:
9.1 sp2 build Moya 9.9.9009.2010 - http://www.1me.com/public/IA/9.1%20sp2%20build%20Moya%209.9.9009.2010/InstallAware_9_With_Runtimes.exe
9.1, Service Pack 3 (build Moya)- 9.1.90140.2010 - http://www.1me.com/public/IA/9.1,%20Service%20Pack%203%20(build%20Moya)-%209.1.90140.2010/InstallAware_9_With_Runtimes.exe
IA 10.10: - http://www.1me.com/public/IA/InstallAware_10_With_Runtimes.exe
IA 11: - http://www.1me.com/public/IA/InstallAware_11_With_Runtimes.exe
IA 12: - http://www.1me.com/public/IA/InstallAware_12_With_Runtimes.exe
IA 2012: - http://www.1me.com/public/IA/InstallAware_2012_With_Runtimes.exe
Uploading the following shortly...
IA NX: - http://www.1me.com/public/IA/InstallAware_NX_With_Runtimes.exe
IA 15.2.3: - http://www.1me.com/public/IA/InstallAware_15_With_Runtimes.exe
If you have any older installers of IA, send them my way so that I can post them to a single source.
My site 1me.com is under development, but for now hopefully these links help.
[b]Passwords:{/b}
Version 9: 'Ozgecan Turna'
Version 10: 'Ozge'
Version 11: 'Ozge Turna'
Version 2012: 'OzgeCan Turna'
Version NX: 'Lizzum'
Version 15: 'Naquadah'
CKAWARE
sinan
Re: Legacy InstallAware Installers can be found here!
Postby sinan » Tue Dec 20, 2011 7:33 pm
Please be advised that you must have a license installer that is exactly synchronized in its version with the trial downloads provided on this page. Using different versions of license installers and trial downloads can wreak havoc with the IDE and the setup engine, which is why InstallAware cannot officially provide these files for you: out-of-sync versions will cause a lot of random issues with your setups purely due to engine/compiler/script version mismatches and cannot be supported by technical support.
ncgjka
Postby ncgjka » Mon Mar 12, 2012 5:32 am
Any chanse you have InstallAware 9 R2 for download? I would really appreciate as I lost my previously downloaded installer.
Michiel2012
Postby Michiel2012 » Tue May 15, 2012 12:24 pm
Hi all,
Does anyone know what the setup password for version 11 is, I have all the files,
setup and license file (no crack or other garbage), I just can't find the setup password
anywhere on my system.
Thanks!
Michiel
bokkie
Postby bokkie » Wed May 16, 2012 12:12 am
Michiel,
I can't remember it exactly, but it's something like "Ozge" or "Ozgecan Turna".
Michiel2012
Postby Michiel2012 » Wed May 16, 2012 6:32 am
Hi Bokkie,
Thanks, but these are the passwords for version 10 and 12 /2012, version 11 has
a different one, I also tried variations of them, without luck :(
Michiel
bokkie
Postby bokkie » Wed May 16, 2012 7:02 am
My apologies.
Try: Ozge Turna
Michiel2012
Postby Michiel2012 » Wed May 16, 2012 7:34 am
Hi Bokkie,
Thanks a million!, that is the correct one!
Michiel
anwars
Postby anwars » Mon Jul 30, 2012 10:34 am
Does anyone know what the setup password for version 7 is?
MaxKielland
Postby MaxKielland » Fri Jan 11, 2013 9:10 am
My backup of InstallAware 9 has become corrupt.
I need InstallAware 9 with file version: 9.6.9006.2009.
I tried the one here in the forum 9 R2 but I can't build my projects with that version. I get Index out of bound -1
I have my own license file and password.
Thank you.
Postby FrancescoT » Fri Jan 11, 2013 11:08 am
Dear Max,
Your issue could be also caused by a possible script corruption.
To verify if this is the cause, try to re-install IA without activating it and see if the issue persist.
Of course, if your license has been emitted for IA 9.6.9006.2009, you can activate this version only using your personal license file.
Aack
Postby Aack » Tue Apr 23, 2013 9:42 am
Thanks for your work on this ckaware; I second your rant!
I tried downloading the "InstallAware NX" files; but they don't appear to have been uploaded to your website. Do you have them available? If so, is there a place I can get them from?
Thanks!
spiritboy2000
Postby spiritboy2000 » Wed Dec 25, 2013 12:10 pm
Hi there,
I am looking for the Installaware V17 Installer password, ...
With Regards, Spiritboy
Postby FrancescoT » Fri Dec 27, 2013 10:31 am
... please write a request to support@installaware.com.
Users browsing this forum: No registered users and 57 guests
