I want to attach a SQL Server database file but there is a couple of steps that I have to take first
It seems that if I copy the database file (.MDF) into the Program Files\\$TargetDir$ I don't have the permission I need to attach it.
If I try to use 'Set Access Control and set 'File System' to 'Grant Everyone' for $TargetDir$ it wont work if 'Simple File Sharing' is enabled; which is the recommended and default XP setting.
If I try to use 'Write Registry' to disable 'Simple File Sharing' it is cached (the purple commands) which means it runs after the 'Set Access Control'
I'm sure it's just me but I need help
Setting File Access & Simple File Sharing
I do this exact procedure in my installation package all the time.
Paste this into the SQL Script edit box for the MS SQL Server Plugin:
Set the variables;
$PRODDATABASENAME$=The name you want the database to appear as in Enterprise manager
$LOGONDOMAIN$=The logon domain of the user (You can obtain this value using "Get System Setting"
The PMD user a a user we create for SQL Authentication, you can use one or edit out the appropriate lines.
The user installing the applicaitno MUST have administrator rights to the local machine.
Of course edit the paths for @filename1 and @filename2.
Hope this helps!
EXEC sp_attach_db @dbname = N'$PRODDATABASENAME$',
@filename1 = N'$TARGETDIR$\\Data\\ProductionDatabase\\mdpmproduction.mdf',
@filename2 = N'$TARGETDIR$\\Data\\ProductionDatabase\\mdpmproduction.ldf'
GO
USE $PRODDATABASENAME$
GO
if not exists (select * from master.dbo.syslogins where loginname = N'PMD')
BEGIN
declare @logindb nvarchar(132), @loginlang nvarchar(132) select @logindb = N'master', @loginlang = N'us_english'
if @logindb is null or not exists (select * from master.dbo.sysdatabases where name = @logindb)
if @loginlang is null or (not exists (select * from master.dbo.syslanguages where name = @loginlang) and @loginlang <> N'us_english')
select @loginlang = @@language
exec sp_addlogin N'PMD', 'greatest', @logindb, @loginlang
END
GO
if not exists (select * from master.dbo.syslogins where loginname = N'$LOGONDOMAIN$\\Domain Users')
exec sp_grantlogin N'$LOGONDOMAIN$\\Domain Users'
exec sp_defaultdb N'$LOGONDOMAIN$\\Domain Users', N'master'
exec sp_defaultlanguage N'$LOGONDOMAIN$\\Domain Users', N'us_english'
GO
exec sp_addsrvrolemember N'$LOGONDOMAIN$\\Domain Users', sysadmin
GO
exec sp_addsrvrolemember N'PMD', sysadmin
GO
if not exists (select * from dbo.sysusers where name = N'$LOGONDOMAIN$\\Domain Users' and uid < 16382)
EXEC sp_grantdbaccess N'$LOGONDOMAIN$\\Domain Users', N'$LOGONDOMAIN$\\Domain Users'
GO
if not exists (select * from dbo.sysusers where name = N'BUILTIN\\Administrators' and uid < 16382)
EXEC sp_grantdbaccess N'BUILTIN\\Administrators', N'BUILTIN\\Administrators'
GO
if not exists (select * from dbo.sysusers where name = N'PMD' and uid < 16382)
EXEC sp_grantdbaccess N'PMD', N'PMD'
GO
exec sp_addrolemember N'db_owner', N'BUILTIN\\Administrators'
GO
exec sp_addrolemember N'db_owner', N'$LOGONDOMAIN$\\Domain Users'
GO
exec sp_addrolemember N'db_owner', N'PMD'
GO
Set the variables;
Hope this helps!
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
Users browsing this forum: No registered users and 86 guests
