dialog issue w/ renaming components
wolbrink
Postby wolbrink » Mon Apr 17, 2006 10:08 am
If I change the name of a component in the dialog editor, any existing object rules that refer to it are dropped.
Postby MichaelNesmith » Mon Apr 17, 2006 2:20 pm
Hi Troy,
You can open the <dialog file>.miaf file in Notepad and update the file directly when you rename components.
wolbrink
Postby wolbrink » Mon Apr 17, 2006 5:49 pm
MichaelNesmith wrote:Hi Troy,
Sure. A bit cumbersome, but it will work.
--Troy
Users browsing this forum: No registered users and 56 guests
