Feature request add ignore case option to If command
Debstep
Post by Debstep »
Id' like to make a request for the following:
When using the IF command currently the option are equal, contains or greater than ( and the opposite)
It would be helpful ot the conains option also incluided the option to ignore case...( with the inverse also being true....if XYZ does not contain ( ignore case)
thanks
Gizm0
Post by Gizm0 »
I don't think it's necessary, because there are too functions, that already make a string uppercase or lowercase, so you can call one of them before calling the IF command, and have the preffered result on your condition.
Panagiotis Kefalidis
Software Design Team Lead
The IF equals and contains parameters will be extended to ignore case in the next update.
