Properties of the MSI and EXE files created during build
Debstep
Post by Debstep »
I notice the following anomallies when viewing the properties of the EXE and msi files when right clicking on the file and selecting properties.
For the exe ( created in an uncompressed build) the Summary tab is completely blank (maybe that is expceted) and the Version tab holds places for Comments ( set to " This instalaltion was built by installaware: "
Product Version is Set to 0,0,0,0 ( How can this be set to the product code?
How does the Comments Section get populated?
Right click on Properties of the uncompressed msi
Select the Summary tab
Select the Advanced button
The revision code shows here but not the product code ( is there a way to add this programmatically ?)
in COMPRESSED build
Right click on the exe
same thing here: How can I edit the Comments and fill out the PRODUCT VERSION ( with the Product code)
Is it also possible to makes these setting promulgate to the MSI created in the Group policy Wizard??
Jeremy Garrett
InstallAware Training
Post by Jeremy Garrett »
Hi Deb,
I noticed that you're trying to do some advanced setup development in InstallAware, and you appear to be somewhat unfamiliar with Windows Installer.
For example, the product code is stored in the MSI, yet Windows Explorer will not display the product code in the file properties field. This is true of all Windows Installer packages.
May I recommend the InstallAware Incident Support service? http://www.installaware.com/support-service-options.htm# For $99 you can speak with an InstallAware expert and rapidly step through the problems you're trying to solve, and get the knowledge transfer you need to better understand the underlying technology.
If additional training is warranted, the the support engineer can schedule an InstallAware WebEx training session ($599), which is customized to your requirements ---allowing you to dive deeper into solving the issues that you need to address. The initial support incident, would then be deducted from your training costs as a skills-evaluation discount.
These additional services are designed to give you everything you need to do amazing things with Windows Installer in a very short amount of time, which is our mission at InstallAware. Taking advantage of these services would ensure that this mission is fully accomplished on your project.
Best regards,
Jeremy
[i]Windows Installer Without Rocket Science[/i]
Debstep
Post by Debstep »
Thanks for the information Jeremy, As much as I would love some sitdown time with someone experienced in Installaware, our current budget does not allow for training options.:cry:
I do have a fair amount of familiarity with Windows installer... ( but I did take a year or so off from actively working with developing msi installations...and was using a different tool to boot)
I am trying to figure out how the Installaware product sets properties etc...which methods are encapsulated within the custom controls created within the how commands are translating to native Windows Installer actions
With Regard to my post above, Since the product code is stored in an Installaware variable, I was trying to figure out how to get it into the EXE properties ( I can of course add this manually if necessary)
And I was wondering why only the revision code shows in the properties for the MSI and the product code does not....
I am converting an installation from a setup created with Wise Professional to the msi format, and there are a few operations not supported by Windows Installer that I need to replicate. It is a challenge :)
Jeremy Garrett
Hi Deb,
The technical support forum is really not an adequate way for InstallAware to provide product training. We will be happy to assist you further under a per-incident support contract.
There are some very exciting new projects in the works, and we need to focus Michael's spare cycles on product testing. This may be an inconvenience to you, but these new features and enhancements will benefit many other users, and your projects as well.
Best regards,
Jeremy Garrett
