Application Runtime Versions
cati-Jason
Post by cati-Jason »
Is there a simple way to know the version of the application runtime being distributed? For example the Crystal Reports .net 4.0 runtime, I know from looking at an installed machine that its version 13.0.0.99, but that was installed with the pre-release version of Mooya. We are now trying to see if the latest RTM mooya version has a newer runtime since SAP's original runtime cut has quite a few bugs.
Thank you
cati-Jason
Re: Application Runtime Versions
Not ideal, but it looks like I can go into the application runtime folder for installaware and look at the MSI package there.
