Fonts
alborg
Fonts
Postby alborg » Sun Apr 23, 2006 3:28 am
Questions:
1) Once a new font is installed, s.a. with the new plugin, if an enduser uninstalls the software, does the font remain in the enduser's computer, or does it get uninstalled too?
2) Can a font be conditionally installed? (i.e. if already present, ignore the installation)
Cheers,
Al
Postby CandiceJones » Sun Apr 23, 2006 1:54 pm
Hi!
1) I believe the font plug-in does not remove the font (I could be wrong - best check the third party plug-in).
2) Sure, just call the plug-in only when necessary.
casic
Re: Fonts
Postby casic » Tue Apr 25, 2006 11:35 am
alborg wrote:1) Once a new font is installed, s.a. with the new plugin, if an enduser uninstalls the software, does the font remain in the enduser's computer, or does it get uninstalled too?
uninstallation is currently not supported by the plugin and there are no plans to support this.
cu
Markus
Markus Diettrich
If it can't be done with InstallAWARE then you are not using Windows
Return to “Non-Technical”
Users browsing this forum: No registered users and 10 guests
