I am building a script that gives a customer the ability to restore a SQL database from a preexisting backup file.
The simplest task is proving the hardest. I would like the customer to browse for the backup file, but am unable to get the File List box to work. Is there a more descriptive example aside from the white pages or help that explains exactly what I should configure?
The error I get when launching the new dialog is I/O error 103.
FileListBox examples?
EpicorRelease
Re: FileListBox examples?
You actually want to use the PTShellList control.
Attached is a sample project - good luck!
- Browse.zip
- (2.54 KiB) Downloaded 389 times
