Multiple file association with different icons
alexbt
Post by alexbt »
I have four file types and one application to open it all, for each file type I have an icon, so I want to assign for each file type own icon.
In practice to all files is assigned the icon of the last created type.
Can anyone help me.
giaviv
Re: Multiple file association with different icons
Post by giaviv »
Just create 4 different icon association - what is the issue?
alexbt
Post by alexbt »
I did, but all file types have the same icon.
Bellow is the source code, for each type I've set different icon.
    Create File Type GWMain file with extensions .ELT and associate with program $TARGETDIR$\Bin\main.exe
    Create File Type GWMain file with extensions .ELV and associate with program $TARGETDIR$\Bin\main.exe
    Create File Type GWMain file with extensions .ELC and associate with program $TARGETDIR$\Bin\main.exe
    Create File Type GWMain file with extensions .ELG and associate with program $TARGETDIR$\Bin\main.exe
All file types have the icon of the last created type.
Icon is set as follow:
alexbt
Post by alexbt »
The problem is that I'm creating four times the same file type (GWMain) for different file extension, seems each entry overwrite previous.
So I've changed file type name for each file extension.
    Create File Type ELT GWMain file with extensions .ELT and associate with program $TARGETDIR$\Bin\main.exe
    Create File Type ELV GWMain file with extensions .ELV and associate with program $TARGETDIR$\Bin\main.exe
    Create File Type ELC GWMain file with extensions .ELC and associate with program $TARGETDIR$\Bin\main.exe
    Create File Type ELG GWMain file with extensions .ELG and associate with program $TARGETDIR$\Bin\main.exe
Now is working how is expected.
giaviv
Post by giaviv »
Great!
