increase minimum memory check to 4 GB?
ttcn2k4
Post by ttcn2k4 »
Hi:
Right now, the IA studio 2012 has a dropdown list with 2GB Physical Memory check ... Is there any way to increase it to 4 GB?
Nhan
giaviv
Re: increase minimum memory check to 4 GB?
Post by giaviv »
Yes there is! You can use the Get System Settings command to obtain a total memory count in MB.
