Access Violation during build
mprentice
Post by mprentice »
Hello. I've been creating builds successfully for weeks. For some reason, I'm suddenly getting Access violation errors when attempting to create a new single file exe. I had been using the debugger on a separate test project and started getting errors there. I thought it only had to do with the test project but when I go back to my real project, I cannot build a new exe. I was able to create an uncompressed file but I need the single file exe. I have tried rebooting my computer but the problem is the same. Can you help please? I am using Installaware Studio 11. The error appears as follows:
Compressed setup files
Prepared SFX data
Error during build: Access violation at address 004E0AE1 in module 'miae.exe'. Read of address 00000010
Thank you.
giaviv
Re: Access Violation during build
Post by giaviv »
Have you recently installed a personal security product?
mprentice
Post by mprentice »
Thank you for your reply. No security products have been installed recently on this machine.
mprentice
Post by mprentice »
Is there something in the registry I can look for to see if that's the cause?
giaviv
Post by giaviv »
Your best bet would be to try and reproduce the issue. Once you are able to isolate and reproduce, please attach the project here.
