Is there a way to silently install InstallAware kits by passing in a config file?
Meaning something like InstallAnywhere’s
installername -f <properties file>
Or InstallShield’s setup -r -f1my_response_file.iss
Where a file is generated that remembers user responses and can be used to automate future installations?
Royi said this was a feature (can't find the email d'oh).
Chris
VERY IMPORTANT - Response file generation
Re: VERY IMPORTANT - Response file generation
Hi Chris,
is this what you was searching for?
- Use Get INI File Settings to read any kind of custom INI file format
- Use command line parameters such as: setup.exe /s "TARGETDIR=c:\path name with spaces" "SERIAL=SERIAL VALUE WITH SPACES" etc.
I have implemented this; however, your competition allows for flags which auto generate response files.
That's what I was asking/ requesting.
Chris
Chris
ssubramaniam
Is there any way to create response file for .msi setup apart from creating our own custom INI file ?
Unfortunately, nothing changed on this.
