How to remove/change “About IntallAware Wizard...” command from Installation dialog system menu?
I have already applied following command as per link http://www.installaware.com/forums/view ... f=2&t=6769
Set Variable MYAHLOGO to TRUE
But it only removes the term “InstallAware Wizard” from dialog caption not from the system menu.
What is the solution for this?
Change/remove System menu command.
chintanpatel7
- Screenshot.JPG (38.55 KiB) Viewed 4937 times
Re: Change/remove System menu command.
Unfortunately you can not remove the About menu item dialog.
you can only choose whether or not to display the system menu.
mikKummerfeld
I need minimum and cancel in the title bar, but not the left menu which includes the "about"..
How can I realise that ?
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Heiko Kummerfeld
MIK GmbH
as I have already said in my previous post, you can choose whether or not to display the system menu dialog.
With Dialog Editor,In the Object property for the dialog, set "bSystemMenu" property under BorderIcons, to FALSE.
