Problem with single file output
kfurnes
Post by kfurnes »
I've got an installer project in IA12. It has been working fine for some time. Now, when I build a single file it looks ok, but when I try to run the installer I get an error saying : "Cannot start setup - the setup file may be corrupt... "
If I build a uncompressed setup, it works fine.
Re: Problem with single file output
if you try to replicate the issue with a simple project from scratch, do you have the issue?
