Silent mode
milhouse
Silent mode
Post by milhouse »
Hi guys!
I was wondering if there is a way for me to display the status of my silent installation in my execution console.
Re: Silent mode
Dear Milhouse,
probably I missed the correct sense of your question, but if are running a silent install no UI is emitted.
Probably do you mean that you want some status lines on CMD console?
If this you should try to add some code in your script to display it ... I never done it ... but it should be possible.
In C/C ++ this is done by calling "printf" function, so with this you should write a dll or an exe to do that.
There are probably easier ways to do it ... now I can not recall.
