Disk space
milhouse
Disk space
Post by milhouse »
Hi!
Is there a way for me to use the content of a static text (Destination folder dialog) in a variable?
The "Required Disk Space" and "Remaining disk Space" works perfectly.
I want to use those values in my MSI code so i can throw a messagebox if there is not enough space left.
I have more than 15 features, so "get component space" will be my last option.
Is this doable?
Re: Disk space
Dear milhouse,
With dialog rules that set the value of an edit control to a static label field, and if the edit control is set to write the value it receives to a variable, this would be possible; but why not use MSIcode?
If you use "Get Total Required Space" command you receive the same value.
Probably I missed something.
