Single file package file version: Wrong
m.duchesneau
Post by m.duchesneau »
We've been using Installaware for almost a year now, and I have never encountered this issue. We have made but minor changes to the installation project lately, and until only beginning of April, we have seen the following issue.
In the project settings, the version is correctly set to "1.0.0.19". Usually, that would make it so that in the Windows file properties, the version would show "1.0.0.19". But now, it is not so anymore. Pleae see screenshot:
Is there anything I can do to solve this?
Thanks!
Mathieu
Re: Single file package file version: Wrong
Dear Mathieu,
You're trying to say,
in your project the version parameter is "1.0.0.19", but ones your setup is built, this have a different property version?
If true, really I haven't never encountered a similar issue.
I know that seems a very stupid question, are you checking the same file?
m.duchesneau
Please make sure you look on the right side of the screenshot, as I have shown the file’s properties very clearly.
Yes, I have confirmed that it is the correct file, generated just before I checked it out.
Thanks!
Mathieu
Dear Mathieu,
please refer to my email message.
