new Dialog to choose a file
Post complete new themes or wizard dialogs here.
Feyh
Post by Feyh »
Hey there,
i wonder if it possible to create a dialog with that i can browse for a file and than add it to the installation?
For example:
My installation let you pick one out of 2 types:
- Full installation
- Developer installation
If you choose the developer installation you have to select a license-file which will be copy-pasted into the installation directory after the installation.
Is this possible? If yes, how?
Greetings,
Feyh
Re: new Dialog to choose a file
Dear Feyh,
You could try if this plugin helps you.
http://www.installaware.com/forum/viewt ... ?f=3&t=503
Feyh
Post by Feyh »
Dear FrancescoT,
yep, that's very useful!
Thank you!
:D
