tofutim
Post by tofutim »
I would like to use some transparency in my setup.bmp so that I can have a custom shape. Is it possible or does it always have to be rectangular? In the attached image, I would like the white to be transparent. I can do it in .png format, but it seems that the splash has to be a .bmp -
setup.zip
(50.63 KiB) Downloaded 412 times
(Also, strangely, cannot upload files of .bmp format to the forum...)
Re: Transparency in setup.bmp
Unfortunately Bitmap file does not support transparency.
mikKummerfeld
Post by mikKummerfeld »
PNG files would be great :) They are much smaller than BMP files and support transparency..
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
I will submit the request to development team ... But I can not promise anything.
