Win 7 x64 Uninstallation issue with VC++10 runtime
moldev
Post by moldev »
We have an installation package which includes the Visual C++ 10 Runtime Redistributable. Our application is an x86 application, but we can run on x64 machines. For that reason, we only check the box that does not say [x64].
Our application installs and uninstalls from Windows XP 32-bit and Windows 7 32-bit without issues. However, we encounter an issue when we try to uninstall from a Windows 7 64 bit- machine in the following situation:
1. Install application on a clean machine without the VC++ 10 Runtime. InstallAware prompts to install the VC++ 10 Runtime package.
2. Finish installing the software.
3. In Add/Remove Programs, select the software package and start to uninstall.
4. While uninstalling, click ‘Cancel’.
5. Select the software package again, and start to uninstall again.
6. A dialog appears stating that the VC++ 10 Runtime needs to be configured. If you click Next, an error appears stating that it cannot find the installation source.
We do not expect the VC++ 10 Runtime to be considered while uninstalling, especially since it installed successfully when the software was installed.
Could anyone please provide some input as to how we can prevent this error from occurring?
Thanks!
Re: Win 7 x64 Uninstallation issue with VC++10 runtime
Personally I use often runtimes in my personal projects and I never faced this issue.
Just a Question:
did you want to say that this happens only if the Uninstall is interrupted .. and then starting it again?
Anyway let me check.
Let me know.
moldev
Post by moldev »
Yes, I meant to say that this happens only if the Uninstall is interrupted, and then started again.
It looks like it would be best for me to send a standalone project which demonstrates the issue....I'll try to do that soon.
If you are able to attach a sample project to test ... will be perfect.
