Target Setup folder
mikKummerfeld
Target Setup folder
Post by mikKummerfeld »
Hello Guys,
two questions:
1. how can I avoid the subfolders "Release\Single" ?
If I want to put my Setup.exe to "X:\Setup\productname" it should be placed here directly without subfolders "Release\Single".
2. The Setup-file-name should be created with variables. e.g Version number and date
It is actually very static. I need the Following like this "Produktname_Version_Setup_date.exe" (MIKolap_8110_Setup_20121604.exe).
How Can I do that without change it every time ?
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: Target Setup folder
Currently you can't do that.
1)The Release folder it is added always.
2)The sutup file name must be Typed.
mikKummerfeld
Please open a request as this is not dynamic enough...
Kind regards
Heiko Kummerfeld
MIK GmbH
I will submit the suggestion to development team ... But I can not promise anything.
mikKummerfeld
Would be very nice. Thank you.
Currently its done by rename with command after miabuild command
miabuild project...
ren D:\setups\product\release\single\MikBisSetup.msi MIK.bis_6150_Setup_20121112.msi
Kind regards
Heiko Kummerfeld
MIK GmbH
