undo option in Dialog Editor
kishorkk23
Post by kishorkk23 »
Hi, I tried the option
Using the Dialog Editor--> Additional-->Rzformshape
I clicked on that and the form borders disappeared. I accidentally saved the form. How Do I revert back the changes to the form?
Re: undo option in Dialog Editor
select the control and delete it (generally just by clicking on the dialog form). Then set the Border Style of the Dialog as you want.
kishorkk23
Hi, thanks for the reply. Yes it did work. But I have deleted the max, min and close buttons. how Do i Add them?
We do not have a option of re-do ??? or undo?
simply set to TRUE bMinimize and BMaximize properties in the Form Object property.
kishorkk23
Well nothing seems to work. Those buttons have been removed permanently. I am not able to get them back...
I have replicated the same on my test machine and works.
I suspect that you erroneously have changed something else.
Can you provide a screenshot of your dialog form properties?
kishorkk23
I have attached the options which I have set. I could not get the minimize or max buttons whatever so...
dialog
dialog
Please set BorderStyle to "bsSingle" .... it is BsNone in your ScreenShot.
kishorkk23
I made the option bsSingle=TRUE. That shows all the buttons in the form.(I have used the Using the Dialog Editor--> Additional-->Rzformshape
and have added a image ).
Still those still buttons are not displayed !!
Is it due to the Rzformshape that I have added?
Are you able to send me a sample to verify that replicate your issue?
kishorkk23
Thanks for the help.
I totally replaced the progress.dfm :)
now I am able to get all the buttons.
But looks like problems are never ending. I added the flash frame. (movie.swf is added)
During progress The flash film does not play !!!
It just shows Flashframe .... :( ...
I have enabled it.
kishorkk23
OK got it... Had to enable billboard in property section...
:D
kishorkk23
Hi, I have added a next button in the progress bar, I gave the option false in the dialog.
Now that I want the button to be completely removed. But once I made it false, I am not able to click on it..
How Can I remove it?
I have attached the snapshot
next button to remove
In Dialog Editor, Use the TAB key to navigate in dialog controls ... then remove the button.
