clear "recent setup projects" list
ttcn2k4
Post by ttcn2k4 »
Hi:
Just wonder if there is any way that we can clear "recent setup projects" list? Thanks
Nhan
bokkie
Re: clear "recent setup projects" list
Post by bokkie »
Good question.
I can't find anything in IA that clears it and I can't find the project names in the registry either. Obviously, they're somewhere, but where exactly...
Dear Guys,
actually the only possible way to do it is to delete the contents of the file mruf.txt (most recently used files) in the InstallAware program files folder.
Hope that helps you :)
pwall
Post by pwall »
Yes it does, thanks! :)
:D :D :D
bokkie
Post by bokkie »
Excellent!
Any chance that useful tip could be added to the F1 help as well?
Dear Guys,
I will try to propose to have a command for this in IA IDE ... probably it is better.
bokkie
Post by bokkie »
Francesco, that would be very useful and much better.
At the same time, do you think you can ask the developers if they could add a button to the toolbar that would clear all breakpoints in a project? I did ask about that a couple of years ago.
I'm still waiting! :D
I will ask for it too!
