ODBC DSN Headaches
mfishman
ODBC DSN Headaches
Postby mfishman » Fri May 04, 2012 4:20 pm
I'm installing a system DSN for SQL Server and though I finally stopped getting keyword-value pair errors (in case anyone else has been suffering through this, it seems you can no longer specify UID, PWD, or LastUser parameters), InstallAware 2012 is not creating my DSN. Any suggestions?
Re: ODBC DSN Headaches
Postby FrancescoT » Mon May 07, 2012 12:50 pm
Your topic has been moved to Technical support forum.
Please try this:
~InstallAware Clipboard Data~
~Set Variable~
~{D0EAECBB-0FF4-409A-8A5B-A42EDEA5B136}~
~NATIVE_ENGINE$MYAH$MYAH$FALSE~
~FALSE~
~Create ODBC DSN~
~{76D079DB-5F9F-4DBB-8AEE-E9E84CD31E7C}~
~MyDns Test~
~SQL Server Native Client 10.0~
~TRUE~
~Server=.\SQLEXPRESS$NEWLINE$Database=master$NEWLINE$Trusted_Connection=Yes~
~Set Variable~
~{30CBBB4D-D54D-4B0D-B228-EA9D5F926885}~
~TRUE~
mfishman
Postby mfishman » Tue Jul 31, 2012 10:04 am
Yes, that works but this doesn't.
~Set Variable~
~{3F9D32E2-6A24-42A9-B7FC-67CBFC9797ED}~
~FALSE~
~Create ODBC DSN~
~{B4501FEA-5845-4928-BD76-263AD2FDA8C3}~
~NASPlant2~
~TRUE~
~Server=[DSNSQL]$NEWLINE$QuotedId=No$NEWLINE$AnsiNPW=No$NEWLINE$LastUser=[SQLUSER]$NEWLINE$AutoTranslate=No$NEWLINE$~
~Set Variable~
~{F82C598B-2ADC-4275-876A-303E1B23F514}~
~TRUE~
Postby FrancescoT » Tue Jul 31, 2012 10:47 am
Verify the the SERVER NAME you are using and add the DATABASE entry to your settings.
mfishman
Postby mfishman » Tue Jul 31, 2012 11:26 am
Server verified, database added - still no joy - see below:
~Set Variable~
~FALSE~
~Create ODBC DSN~
~NASPlant2~
~TRUE~
~Server=[DSNSQL]$NEWLINE$Database =master$NEWLINE$QuotedId=No$NEWLINE$AnsiNPW=No$NEWLINE$LastUser=[SQLUSER]$NEWLINE$AutoTranslate=No$NEWLINE$~
~Set Variable~
~TRUE~
Postby FrancescoT » Tue Jul 31, 2012 11:54 am
Let me prepare a test environment and I will be back to you as soon as possible.
Postby FrancescoT » Wed Aug 01, 2012 9:07 am
Dear Mfishman,
the problem seems caused by LastUser Parameter.
I'm still checking it but I do not know actually when I'll be able to tell you more.
ohoover
Postby ohoover » Wed Aug 01, 2012 2:18 pm
Hi Francesco. I also had the same problem yesterday. I had to remove the "LastUser" parameter as well in order for it to work. From what I read, having "LastUser" can be a security issue so that could be why it is not valid.
Postby FrancescoT » Thu Aug 02, 2012 3:09 am
Many thanks!
I found the same.
Seems that the use of "LastUser" parameter is not allowed anymore.
Let me see if I am able to find more detailed info about.
Users browsing this forum: Bing [Bot] and 58 guests
