InstallAware 11 setup password
Michiel2012
Postby Michiel2012 » Tue May 15, 2012 5:51 am
Hi All,
I've been having a problem with a corrupted disk in my computer, I did backup all my setup files,
and the installer of InstallAware 11 and license file, the only thing I can't seem to find is the
installer setup password for Installaware 11, does anyone know what it is ?
Thanks alot!
Regards,
Michiel
Re: InstallAware 11 setup password
Postby FrancescoT » Tue May 15, 2012 11:41 am
Dear Michiel,
Try if the following link helps you:
http://www.installaware.com/forum/viewtopic.php?f=2&t=7904
Michiel2012
Postby Michiel2012 » Tue May 15, 2012 12:20 pm
Hi Francesco,
I already found that page, but I have all the files, the only thing I need
is the password for the installer, I have it for version 9, 10 and trial 2012
just not for 11 :(
Kind regards,
Michiel
Michiel2012
Postby Michiel2012 » Wed May 16, 2012 7:41 am
Thanks to Bokkie, I got the correct password, it's Ozge Turna
Return to “Non-Technical”
Users browsing this forum: No registered users and 8 guests
